Great Feature: Syncing Graphs
Postby sharpaaa » Sun May 02, 2021 12:54 pm
This rather long command name, Scrolling Investment Based Graphs Changes Investment Stack Order, is a great feature to keep both the graphs I have displayed in sync when I scroll through my investments.
sharpaaa
Postby 4MoreProfits » Fri May 28, 2021 9:24 am
This can be accomplished now. If you have two graphs split screen and the portfolio editor open. 1. Click on the first graph and then select a stock in your portfolio. the graph will change .
2. Now click on the second graph and then select the same stock from the portfolio editor and the second graph will change
Now as you click on different stocks in the portfolio editor both trends will display the date. I use this to show a cost/price graph and a MA overlay graph for the same stock. I usually have 2/3 of my screen split top to bottom with the two graphs stacked and the remainder of the screen showing my portfolio editor.
The only drawback is you must do this every time you move to a new portfolio.
4Profits
4MoreProfits
