Suggestion for the Report Period/Date
Postby coolspot » Tue Jul 19, 2022 5:40 am
It will be great if there is a quick way to generate report for certain period. For example, to do quarterly report for a year, usually we have to set the date one by one.
It will be great if we can set "Quarterly Report" , and compared over "3 period". So if we run Q2 2022 report, and run 5 period, it will generate Q1 2021 to Q2 2022. Same with the year also.
coolspot
Postby Mark » Tue Jul 19, 2022 7:51 am
Hi coolspot,
Okay, understood, thanks for the idea.
