New Alerts
Postby 4MoreProfits » Fri Jan 06, 2023 9:27 am
I have an idea for modifying the Alerts. Especially when using the Technical Analysis graph.
1. This graph uses two moving averages on the top trend.
It would be nice to have an alert generated when:
a. the overlaid trend lines cross each other done like alerts are now or with the option for
this to be a continuous alarm, or a once and . (Happens every time they cross in any
direction and when it triggers it does not have to be re-initialized to occur again, with a
possible small symbol placed when the alert occurs).
b. when the value crosses either of the overlaid trends. again with the same features
listed in (a.) above.
2. for the bottom trend MACD vs Signal:
a. On the bottom trend an alert to be generated anytime the MACD line crosses the Signal
line in either direction. Since his happens often this alert should be a continuous alert so
it doesn't need to be reinitialized every time. Maybe just put a dot or some small signal
when it occurs with an option check box to be 1 and done. If the one and done is
un-cheked it would revert to a continuous.
Also not sure if it is possible but it would be nice to be able to change some of the properties with a left mouse click. Like for overlaid trends the week selection and values. Also on the MACD vs Signal to be able to change the values for MADC and Signal trend calculations.
Jim
4MoreProfits
Postby Mark » Fri Jan 06, 2023 11:25 am
Hi Jim,
Thanks for the ideas/feedback. These do sound useful.
