Yahoo server via USA
Postby progers1947 » Fri Jul 21, 2023 4:26 am
Mar, you said "2) Use Fund Manager with a VPN and from a connection outside a GDPR country, like the United States for example. Accessing Yahoo from a VPN like this will enable you to then retrieve prices, even once you're not using the VPN, as you've obtained the necessary cookies.
Fund Manager - Portfolio Management Software"
I tried that and it works if I connect my VPN to a US site but as soon as I return to the UK it fails again. Are there cookies somewhere I need to clear first?
Peter
progers1947
Postby Mark » Fri Jul 21, 2023 7:15 am
Hi Peter,
No. That technique worked at the time, but currently the problem is a bit different. You'll have to retrieve with the VPN on, or switch to a different quote server.
Postby MichelV » Fri Jul 28, 2023 9:20 am
Since a week or so, Yahoo price retrieval is also broken via Canada. I'm able to update prices using Historical. Any idea if this is broken for good or do you foresee a patch?
Michel.
MichelV
Postby Mark » Fri Jul 28, 2023 2:26 pm
Hi Michel,
I expect a patch will be able to fix it. After August 4…
Postby Mark » Thu Aug 03, 2023 7:05 pm
Hi Michel,
We have just released an update to fix Yahoo. Please use "Help / FM on the Web / Check for Updates..." to download quote module 584.
Please note, this will not fix Yahoo for connections coming from within Europe. If you are within Europe you will need to use a different server, or access Yahoo through a VPN connection to another country, like the US.
Postby MichelV » Fri Aug 04, 2023 4:54 am
Now working within Canada
Thanks Mark.
MichelV
Postby Mark » Fri Aug 04, 2023 7:35 pm
The functionality of retrieving from Yahoo in Europe has been restored. Select "Help / Fund Manager on the Web / Check for Updates..." from within Fund Manager 2022 or 2020. For more details, see this announcement.
