Dialog for New Investment File Format
Postby DukeWeston » Thu Mar 14, 2024 6:30 pm
While upgrading to FM 2024 I noticed that this dialog is not wide enough to display the filepath and filenames. Although it is possible to move the cursor onto each filename and scroll it for viewing, I'm sure that wasn't intended.
Better would be a wider dialog, or allowing the filename to wrap to the next line.
I've attached a screenshot ...
Regards.
DukeWeston
Postby Mark » Thu Mar 14, 2024 7:19 pm
Hi DukeWeston,
Thanks for the feedback. We'll both make the dialog a bit wider, and also have the text wrap when needed.
