Employee Stock Options
Postby rdg » Mon Jan 18, 2010 7:34 pm
Is there a way to track vesting employee Stock Options in Fund Manager instead of entering them manually as they vest?
Quicken has a neat section that allows you to enter the original date and price and time period and then "vests" them as they come due.
rdg
Postby Mark » Tue Jan 19, 2010 8:12 am
Hi rdg,
Sorry, no, we don't have such a feature. Thanks for the feedback though.
Postby Kodiak73 » Fri Apr 16, 2010 12:03 pm
The previous poster wanted to track vesting, but I had a different question. Apologies if it is obvious.
How can I enter a vested employee stock option so that I can track "above and below water" value?
An example. Suppose I have 1000 vested options of Company XYZ. These options have a Grant Price, of say $20.00. When the current Stock price of XYZ is $25.00, then the "above water" value is 1000*25 - 1000* 20 (or 1000* (25-20)) which equals $5K.
But if the stock price is less than $20.00, then value would be zero.
Thanks for any tips or help.
Aaron
Kodiak73
Postby Mark » Fri Apr 16, 2010 5:09 pm
Hi Aaron,
Unfortunately, we don't offer a way to do this either... If you are above water, you can keep track of the net profit by recording transactions in 2 investments, one negative cash amount for your cost, and one for the current market value of the shares. The net result is the difference, and how much they are worth to you. This only works if you stay above water though... Employer granted options is an area we hope to improve in a future version.
Postby Kodiak73 » Sat Apr 17, 2010 1:08 am
Thanks for the quick reply. Definitely look forward to this as a feature in future release.
Aaron
Kodiak73
