Entering license key
Postby Fingergold2 » Sat Jan 30, 2010 5:13 am
I have just purchased the new version of the Professional version as an upgrade. I can find no "Enter License Key" command under the "Help" command. How do I enter the key?
Fingergold2
Postby Mark » Sat Jan 30, 2010 9:34 am
Hello Fingergold2,
If you do not have an "Enter License Key..." command under the "Help" menu then that means you've already entered your license. You can verify your license status by looking under "Help / About...". Once you've entered your license into any 10.x version you don't need to enter it again. If you install a new 10.x version (like the just released 10.4), your license status is maintained. It isn't necessary to enter it again.
Postby Fingergold2 » Sat Jan 30, 2010 12:12 pm
Mark wrote:Hello Fingergold2,
Thank you, Mark. As usual, you folks are way ahead of me!
:D :D
Fingergold2
