Changing Date Range for Graphs and Yields
This dialog is available from the View / Dates... menu command under the Graphs window.
This dialog box allows you to change the graph’s date range. Yields displayed above the graphs will also reflect this date range.
Choose from the list of pre-defined date ranges, or enter your own From and To dates. The following pre-defined date ranges are available:
Custom
any other date range setting you choose
Today
the current date for both starting/ending dates
Yesterday
day prior to current date for both starting/ending dates
1 Week
1 week span ending on the default ending date
1 Month
1 month span ending on the default ending date
3 Months
3 month span ending on the default ending date
12 Months 12 months (1 year) span ending on the default ending date
Earliest price to date from the date of your first recorded price to the default ending date
Earliest transaction to date from the date of your first recorded transaction to the default ending date
Week to date beginning of the default ending date week to the default ending date
Month to date beginning of the default ending date month to the default ending date
Quarter to date beginning of the default ending date quarter to the default ending date
Year to date beginning of the default ending date year to the default ending date
Last Week last complete calendar week prior to the current date
Last Month last complete calendar month prior to the current date
Last Quarter last complete calendar quarter prior to the current date
Last Year last complete calendar year prior to the current date
Current Week complete calendar week containing the default ending date
Current Month complete calendar month containing the default ending date
Current Quarter complete calendar quarter containing the default ending date
Current Year complete calendar year containing the default ending date
The "default ending date" is the date of your last recorded price on or before the current date. Many of the pre-defined date range choices are also available as keyboard shortcuts.
If this is an investment based graph being adjusted there will be a check box available:
Apply Changes to All Open Investments
Select this if you wish to make the specified date range settings effective for all currently opened investments. The date range settings applied to all other investments can be determined in either of 2 ways:
Use Same Dates
uses the exact same dates as displayed in the date controls to update all the other investments
Recalculate Pre-Defined Range For Each Investment uses the specified pre-defined range to recalculate the date range for each investment
Often these 2 options will cause the same date range to be set, but in some cases there are differences. For example, the Earliest to date date range would result in different date ranges for the 2 options. Another example is if any of your investments have a different default ending date. In this case all the pre-defined ranges ending on the default ending date would be different for the 2 options.
Storing Graph Dates in the Portfolio File:  When you save a portfolio and a graph window is open, all the date ranges are memorized in the *.mm4 portfolio file, so the next time you open your portfolio, the dates will be restored as they were when you last saved. If the ending date of your graph is set to the default ending date, the graph's ending date will "float" as the default ending date changes. If you have on the option Start Date Floats with End Date, then the starting date will also be adjusted as the end date moves, to keep a constant distance between the start and end. If the saved end date is not at the default ending date, it will remain fixed to that date.
Usage Tips:
When the Dates... toolbar button () is enabled, there will also be a dropdown combination box on the toolbar that allows you to quickly select from a variety of common date ranges:
1W
1 Week span ending on the default ending date
2W
2 Week span ending on the default ending date
3W
3 Week span ending on the default ending date
1M 1 Month span ending on the default ending date
2M 2 Month span ending on the default ending date
3M 3 Month span ending on the default ending date
6M 6 Month span ending on the default ending date
1Y 1 Year span ending on the default ending date
2Y 2 Year span ending on the default ending date
3Y 3 Year span ending on the default ending date
5Y 5 Year span ending on the default ending date
10Y 10 Year span ending on the default ending date
MTD Month To Date: beginning of the default ending date month to the default ending date
QTD Quarter To Date: beginning of the default ending date quarter to the default ending date
YTD Year To Date: beginning of the default ending date year to the default ending date
PRC Price inception: date of your first recorded price to the default ending date
TRN Transaction inception: date of your first recorded transaction to the default ending date
... custom date range, select this to open up the View / Dates... dialog
For investment based graph types you can hold down the Shift key on your keyboard while making a selection from the dropdown combination box.  Holding down the Shift key will cause the date range selection to be applied to all investments in the active portfolio.  Otherwise, it is only applied to the topmost investment.
By using the mouse or keyboard shortcuts the date range can be adjusted quickly without using this dialog box. See mouse commands. There are also many other keyboard shortcuts for zooming and scrolling the date range.
You can adjust the date range and calculate the gph (short for "graph") yield for any desired time period. The gph yield is the yield for the displayed graph date range and will be displayed above the graph if yields are turned on.
See Also
About Graphs
Changing Vertical Scale
Mouse Commands
Keyboard Shortcuts
Fund Manager Home
