This dialog is available by pressing the "Configure..." button from within the Alert Options Dialog.
Fund Manager can send e-mail by either using your installed default mail client, or it can send the mail itself directly to your SMTP mail server. When using your default mail client (such as Outlook, Windows Live Mail, Outlook Express, or Netscape) it must be MAPI compatible. Choose one of the following e-mail configurations:
Use MAPI Client for Sending E-Mail |
Fund Manager will use your default mail client for sending e-mail. |
Send Directly to Mail Server |
Fund Manager will send the e-mail alert directly to your SMTP mail server. |
MAPI Options: If your MAPI e-mail program uses an e-mail profile, specify the profile name and password here. If you do not need to specify a profile name simply leave these fields empty.
Use the "Test" button from the Alert Options Dialog to verify these values are set appropriately.
