This dialog is used to define the properties of a particular management fee method.
| Name | Enter any name to use for this management fee method. This name will be displayed in the "Fee Method" column of the Management Fees report. |
| Method | No Fee:
 % of Beginning Value:
 % of Average Value:
 % of Ending Value:
 Fixed Fee:
 % of Ending Value plus Performance:
| Percentage | For any of the percentage of managed value methods this option controls that percentage. Choose from any of the following choices: Fixed %:
 Tiered %:
 Fixed % by Investment Type:
When using the % of Ending Value plus Performance method you can charge management fees as a combination of fees on managed value (non-performance) plus fees based on performance. There are some important factors to be aware of when using this method:
The following options are available when using the performance method. All percentages are entered as annual percentages.
| Fixed % of Ending Value | The specified percentage is applied to the managed value. Enter as an annual percentage. |
| Performance Fee % | The specified percentage is applied to profits earned above the High Water Mark. For example, assume quarterly profits of $10,000 and a specified Performance Fee % of 10%. The performance fee for the quarter will be $1,000, which is 10% * $10,000. |
| Billing Period | Select the frequency that management fees are charged. Quarterly and Annual billing periods are supported. Calendar based periods are used. For example, annual billing periods always start on January 1. Quarterly billing periods start on the first day of January, April, July, and October. |
| Start Billing Method At | |
| Portfolio Inception | Billing is started on the date of the first transaction in the sub-portfolio. The starting High Water Mark is zero in this case. |
| Selected Date | Billing is started on the specified date. Choose to either specify a starting High Water Mark or use the beginning market value on the specified date. |
| Hurdle | Choose whether or not to enforce a Hurdle Rate, and what type of Hurdle Rate to use. When using a Hurdle Rate the performance of the sub-portfolio must exceed that of the Hurdle Rate before a performance fee can be charged. Both "Soft" and "Hard" Hurdle Rate options are available. When using a Soft Hurdle Rate the performance fee % is applied to all profits earned. When using a Hard Hurdle Rate the performance fee % is applied only to the profits exceeding the Hurdle Rate. The Hurdle Rate can be a combination of a selected benchmark investment plus a fixed hurdle rate adder. When specifying the fixed portion of the hurdle rate the percentage is entered as an annual percentage. For example, if you choose to not use a benchmark rate investment and specify a 4% fixed Hurdle Rate %, a quarterly performance greater than 1% would be required to charge a performance fee. |
| Include Accrued Interest in Calculations | Includes accrued interest in the performance fee calculations, such as when determining the profits earned, and whether or not the Hurdle Rate was satisfied |
| Calculate HWM Assuming Fees Paid Externally | When calculating the High Water Mark (HWM) assume that fees are paid externally, and not deducted from the account. When fees are deducted from the account (this option is OFF), the HWM is reduced by the amount of the fees paid. Normally this option would be left off and you would keep track of your account fees paid in Fund Manager. |
