This dialog is available from the Edit / Update Price / Multiple Investments - Repeat... menu command in the Graphs window. It is also available under the Edit / Investment Data / Update Price / Multiple Investments - Repeat... menu command in the Portfolio Editor window.
This dialog box allows rapid entry of multiple prices for as many open investments as you choose. Enter the date the price information is to be updated for in the date edit box. Uncheck the check boxes associated with the investments you do not wish to update. Fill in the price information for the investments you do wish to update. The volume, high, and low edit boxes are optional, and may be left blank.
Select the 'Update' push button to update the current price information for all investments whose checkbox is checked. After selecting this push button, the date will automatically be incremented by one day, and you may continue entering price information for the same investments.
Select the 'Update/Next' button to update the prices for all currently displayed investments, and display the next 9 investments, so that they may also be updated.
Select the 'Stop' push button to quit updating prices.
