This dialog is available from the Help / Enter License Key... menu command.
This dialog is used to enter your license information. You will receive
a license from Beiley Software by email when you purchase
Fund Manager.
Copy the license from the email and paste it into this dialog, and then press
OK.
The copied license should include all lines starting with "---BEGIN LICENSE---"
up through and including the line with "---END LICENSE---". You can copy
more than this, like the whole email, but at a minimum it must include the
section with the license. A sample license will look like:
---BEGIN LICENSE---
<some text>
---END LICENSE---
