"Skins" can be used to memorize and recall display preferences. These display preferences include all the pen sizes, colors and fonts for graphs and reports. To store the current display settings to a new theme, use the menu command Options / Skins / Memorize Skin.... You will be given the opportunity to assign a name to this skin. To recall any previously saved skin, select it from the Options / Skins menu. You can also select the "Default" skin, which will restore all the program's default display settings.
