Portfolio Editor list templates are saved column settings for the
Portfolio Editor list view. Templates
remember which columns are displayed, and their order. Templates are intended to
allow you to quickly switch between different desired list view configurations.
You can save as many templates as you wish. To save a template, right
mouse click on the list view column header and choose
Save New Template... from the popup menu. You will then be able to
assign a name to this new template. New templates store the current list
view settings. You can also save a new template from the Edit Template
List Dialog.
To recall a template, right mouse click on the list view column header and
choose the desired template name from the popup menu. You can also recall
a template by selecting the Template... button
in the Portfolio Editor Columns to Display
Dialog.
Portfolio Editor Columns to Display Dialog
