To open a portfolio use the Open
Portfolio... command from the
top level File menu. You can also select
the button from the toolbar. Your most recently
opened portfolios are listed at the bottom of the File
menu. You can open any of these portfolios by just selecting them from
this list. By default, the portfolio you had open when you last quit Fund
Manager will be re-opened when you start Fund Manager.
Portfolios can also be opened using command line arguments.
