This dialog is available from the File / Export / Transactions / Generic... menu command.
The following choices are available:
Select Portfolio To Export From |
Transactions from all investments in the selected sub-portfolio will be exported |
Include Hidden Investments |
Check this option to export transactions from investments marked with the hidden attribute |
Date Range to Export |
Choose to either export transactions from all dates, or only within a certain date range (inclusive) |
Export Format |
Specify how the output will be exported. Uses the same keys and format string as the generic transaction import. |
