Transfer of Fund Manager to new computer
Postby Peter O'Malley » Mon Mar 31, 2008 6:00 am
I wish to transfer all my Fund manager files to a new computer. Do you have a recommended procedure. I ran into trouble when I first loaded Version 8.10 onto the new computer and then copied all the folios that appear in the Fund Manager folder within my Program folder on the C drive of the old computer via a portable disk. Formats etc appeared to be lost and some of the historical prices etc did not seem to transfer. I have now uninstalled Version 8.10 and deleted the copied folders.
Peter O'Malley
Postby Mark » Mon Mar 31, 2008 8:58 am
Hi Peter,
Yes, we do. You can read all about it here:
http://www.fundmanagersoftware.com/newcomputer.html
Let me know if you have any un-answered questions after reading this.
Postby Anthony Marshall » Thu Apr 03, 2008 8:22 pm
I think I have te same issue as Peter - I wish to transfer my files and FM tool to a new computer, so I:
* downloaded the new executable (8.10) and installed it on the new computer,
* regitered it using my 8.x key and password,
And all seemed well until:
I attempted to copy the .dat and .mm4 files from the old computer. Not all of the .dat or .mm4 files are visible to copy. It seems the most recently created portfolios and investments are invisible to Windows explorer.
Interstingly, if I view the folder where they are saved using the FM program (for example, from the "open investment" dialogue), I can see them. It seems only FM can accsss them.
So when I copy the "My_data" folder using Windows Explorer, some data is lost.
Any ideas? I dont think its associated with the registry keys.
Tony
Anthony Marshall
Postby Anthony Marshall » Thu Apr 03, 2008 9:01 pm
After a bit more research in your Forum I found the thread called "Fund Manager files in Windows Vista" which explains where the "invisible" files are.
I've now copied the files from the "VirtualStore" location to a location in a public place so all should b well.
Cheers
Tony
Anthony Marshall
Postby johnreid » Sun Apr 06, 2008 7:21 pm
I, too, wish to transfer to a new/old computer, acutally moving back from a laptop with Vista to my main desktop computer with XP. I downloaded the latest version, opened the HELP and tried to imput my codes, the serial number and the license key. The programme would not take the information. What I got was this message:
Invalid License
Please make sure to enter all fields exactly as provided.
All fields are case sensitive.
I have put the codes in as they worked on the other computer but the new version of Fund Manager will not accept them.
Would you let me know what I can do about this?
johnreid
johnreid
Postby Mark » Sun Apr 06, 2008 8:03 pm
Hi johnreid,
Please email us with the information you're entering, along with the version you're using. You can find your version under "Help / About...". Please include both the version number and type (Personal, Professional, or Advisor). You can email us from here:
Users browsing this forum: No registered users and 27 guests
