Additional User-defined Designations
Postby senior » Fri Sep 14, 2012 8:11 am
is there a way to increase the number of user-defined distributions in menu <F5>
| data type | distributions (all) | ... by, say, two? I’ve already used up the
available two user-defined tags by renaming them to my needs but I’d like to
have at least two further tags without having to sacrifice standard designations.
Greetings, Peter
senior
Postby Mark » Fri Sep 14, 2012 9:13 am
Hi Peter,
Sorry, no, you can't add additional distribution types. As you've seen, you can change the names/purpose of any of the available distribution types (Options / Distribution Labels...), but you can't increase the number. If you want to check to see which distribution types you're using you could run a Distribution Summary report at your top sub-portfolio level for the history of your portfolios. If you don't trade bonds, you might want to use the Accretion/Amortization distribution types for some other purpose.
Postby senior » Fri Sep 14, 2012 9:29 am
many thanks for the quick reply. I feared that your answer would be like this as I’ve tried a lot of possibilities before writing here to the forum.
Have a nice weekend,
Peter
senior
