New File?
Postby heidiasst » Thu Jan 10, 2019 9:12 am
Good Morning Mark,
For whatever reason when transferring data onto this computer, the file you created long ago (Closed Accounts) did not come over. I have transferred the data onto a flash drive but, am not seeing how I set up a separate file to download these "Closed Accounts" into.
This is not a new Portfolio rather a new file.
Thanks as always for your assistance.
Heidi
heidiasst
Postby Mark » Thu Jan 10, 2019 10:20 am
Hi Heidi,
What type of file are you asking about? FM has 3 general types of files:
.FMB: Backup file
.MM4: Portfolio file
.DAT: Investment file
If you're asking how to open a .mm4 file, just use "File / Open Portfolio..." and you can open it. Portfolio files will also open whatever .dat files belong in sub-portfolios that are part of this portfolio file.
Postby heidiasst » Thu Jan 10, 2019 10:40 am
.MM4 file
heidiasst
Postby heidiasst » Fri Jan 11, 2019 11:08 am
The "Closed Account.MM4" file no longer exists
I need to know how I go about adding this back so that I can move the old data over
heidiasst
Postby Mark » Fri Jan 11, 2019 11:38 am
Hi Heidi,
To create a .mm4 file, use "File / Save Portfolio As...". You might want to first do "File / Close Portfolio" so you can then create a new/empty .mm4 file that you can start moving things into.
