Close Portfolio
Postby elliots » Wed Dec 23, 2020 1:07 pm
I accidentally hit "Close Portfolio" on the FILE MENU and now all I can see in Portfolio Editor is Master Portfolio and I can't get to any of my sub-portfolios. How can I recover? I assume I can restore from a backup but I will lose about 4 hours of detailed cleanup work.
elliots
Postby Mark » Wed Dec 23, 2020 2:01 pm
Hi elliots,
You want to re-open your portfolio. It is probably the #1 entry on the list of most recently opened portfolios at the bottom of the File menu. Either pick it from there, or use "File / Open Portfolio..." to open it. This method requires you know the filename and where you've saved it, but if you're not sure, just pick the top entry (below "Exit" at the bottom of the "File" menu).
Postby elliots » Wed Dec 23, 2020 6:05 pm
Many Thanks
elliots
