Anyone having problems logging into the app? It won't let me login and tells me:
IO error: java.security.cert.certpathvalidatorexception: trust anchor for certification path not found
However, I can login on the website through the client portal.
App problems
IO error: java.security.cert.certpathvalidatorexception: trust anchor for certification path not found However, I can login on the website through the client portal.
Hi Alexanderfrood,
To use the App now you must have Android 7.1.1 or later. Our site uses a certificate from LetsEncrypt, and their trusted root certificate needs 7.1.1 or later. For more info, see: https://letsencrypt.org/docs/certificate-compatibility/
Thanks for the information. I'll delete the app.
Who is onlineUsers browsing this forum: Google [Bot] and 7 guests |
