WIN 10 Glich with Upgrade
Postby pdgood » Fri May 06, 2022 8:00 am
The program appears to load from the task bar but immediately minimizes and then will not respond....!?
Note: I have the Upgrade on Win 7 as well and have no issues. My browser is FireFox for both machines. I've no problems with other applications on 10.
Your help is appreciated in advance.
PS: I really like your choice in USP stamps!
Phil Garner
pdgood
Postby Mark » Fri May 06, 2022 8:36 am
Hi Phil,
Can you try uninstalling it, and re-installing?
Postby pdgood » Mon May 09, 2022 7:48 am
I have not tried to re-install . Will this pick-up my portfolios at the set-up even after I uninstall?
Phil
pdgood
Postby Mark » Mon May 09, 2022 9:24 am
Hi Phil,
No, it wouldn't re-open your same portfolio automatically if you uninstall. When you uninstall all your global preferences are removed. You would have to use "File / Open Portfolio..." to re-open it.
If you're comfortable using regedit, you can try fixing this issue without uninstalling. I suspect some window size/position preference is messed up, and you can remove this by doing this:
1) Exit Fund Manager if it is running
2) Use "regedit" and delete the key:
HKEY_CURRENT_USER\SOFTWARE\Beiley Software\Fund Manager\CurrentVersion\Window
3) Re-start Fund Manager
Postby pdgood » Mon May 09, 2022 10:36 am
Just to be clear, after the uninstall/reinstall will my existing portfolio files still be available? Or will I need to re-enter,ie., create them again?
Phil
pdgood
Postby Mark » Mon May 09, 2022 10:39 am
Hi Phil,
Uninstalling does not remove your data files. It just removes the program and your preferences. You would have to re-install Fund Manager, start up the program, and use "File / Open Portfolio..." to open your *.mm4 file. Do you know where your *.mm4 file is located now? The default is:
My Documents \ Fund Manager
but you can store your data anywhere. If you're not sure, and you can't open FM, you can search your computer for *.mm4 to find where your portfolio file is located.
So, no, you would not have to re-enter your re-enter your portfolio data.
Postby pdgood » Mon May 09, 2022 11:14 am
Thanks Mark,
I have found the files and I should be good from here!
You guys have a Great program and your tech support is Awsome!
Sincerely,
Phil
Customer since 2017
pdgood
