Importing CSV Price Files
Postby asg » Fri Nov 26, 2010 9:31 am
I am evaluating Fund Manager and was trying to import some price histories from CSV files they import except the leading digit of the price/NAV is lost eg
1.25 is imported as 0.25, this appears to affect all prices.
I am using MM/DD/YY, NAV
Can you suggest anything
Regards, Andrew
asg
Postby Mark » Fri Nov 26, 2010 9:39 am
Hi Andrew,
Does your CSV file really have a space after the comma, and before the price? You specify:
MM/DD/YY, NAV
which would match something like this:
6/25/2010, 1.25
but if your CSV file really looks like this:
6/25/2010,1.25
then you would want to use the format string:
MM/DD/YY,NAV
If that doesn't resolve it, please post a sample line or two from your CSV file.
Another tip is to look at your CSV file in a text editor, like Notepad, instead of Excel. In the text editor you see exactly how the file is formatted.
Postby asg » Fri Nov 26, 2010 9:44 am
Thanks Mark.
I had a space where I shouldn't.
Regards, Andrew
asg
Users browsing this forum: Google [Bot] and 1 guest
