Internet Price Retrieve not working
Postby csharin » Fri Apr 05, 2013 12:20 pm
HI Mark, I have the latest 442 and my internet connection is good. Tried Yahoo historical and MSN histoical, no prices received.
csharin
Postby Mark » Fri Apr 05, 2013 12:47 pm
Hi csharin,
What date range did you enter? Sometimes the historical servers only have prices up through the prior day, so if you're just asking for today's prices with a historical server it may not be able to provide those. Use a current server instead in this case. A current server is one that doesn't have "Historical" in the name, like just plain "Yahoo".
Postby csharin » Fri Apr 05, 2013 12:58 pm
Thanks for the quick response Mark. I was using 3/29/13 to 3/29/13.
csharin
Postby Mark » Fri Apr 05, 2013 1:02 pm
Hi csharin,
The markets were closed on 3/29/13, as it was Good Friday. Therefore, there won't be any closing prices available on that date.
Postby csharin » Fri Apr 05, 2013 1:13 pm
That was it. I always update prices for the last day of the month. It's amazing that I didn't run into this in the last 18 years! When was the last year Good Friday fell on the last weekday of the month?
Thanks!
Cliff
csharin
Postby csharin » Fri Apr 05, 2013 1:18 pm
Hi Mark, One other thing I have been meaning to ask you about. I did price retrieve with range 3/28 to 3/28, but it also pulls in the current price 4/5. I don't want this since I compare total value to my broker monthly statements as a check.
csharin
Postby Mark » Fri Apr 05, 2013 1:24 pm
Hi csharin,
That shouldn't happen. Are you sure it came in with the historical retrieve? Try deleting both prices, and re-do the historical retrieve. It should only update for the date range you request.
Postby SteveK » Wed May 08, 2013 12:36 am
I have a problem downloading prices on Bloomberg since yesterday (Bloomberg Historical is fine). Is there a know issue here ?
thanks for your reply.
SteveK
Postby Mark » Wed May 08, 2013 8:50 am
Hi SteveK,
It seems Bloomberg has eliminated some international stocks from the available quotes on their website. Just yesterday we added the "Reuters" server to help address this. You can download quote module 443 using "Help / FM on the Web / Check for Updates...". The Reuters server uses different symbols for the international exchanges than Bloomberg did, so you will need to visit the Reuters website to look up the required symbols, and change them in Fund Manager.
The other option is to just use Bloomberg (Historical) instead of Bloomberg for these quotes.
Postby SteveK » Wed May 08, 2013 9:10 am
Ooh no ! I have to individually change the investment symbols one after the other ! Is there any reason they did this? Maybe is reactivated later on ?
SteveK
Postby Mark » Wed May 08, 2013 9:23 am
Hi SteveK,
If you use Bloomberg (Historical) you wouldn't have to change the symbols. I'm not sure why they did this, or if they will come back...
Postby SteveK » Tue May 14, 2013 11:56 am
Hi Mark
Which server would you recommend to use when updating prices (as opposed to updating historical prices), now that Bloomberg for current prices is no longer available ?
regards,
Steve
SteveK
Postby Mark » Tue May 14, 2013 12:03 pm
Hi Steve,
If your quotes are available on Yahoo, I would suggest that server. It is fast and stable.
Postby SteveK » Fri May 31, 2013 2:17 am
Yahoo (Real-Time) is only available in the professional and Advisor versions, unfortunately.
SteveK
Postby Mark » Fri May 31, 2013 9:08 am
Hi Steve,
I was suggesting using the "Yahoo" server, not "Yahoo (Realtime)". These are 2 different choices, and the "Yahoo" server is available in all versions.
Next
