Cannot receive Merrill Edge transactions
Postby surendar jeyadev » Sun Oct 06, 2013 3:56 pm
I cannot retrieve the transactions from my Merrill Edge account for the period
1-30 Sep 2013. I have not had any problems retrieving transactions from any
institution so far.
I get a pop up window that says
Post HttpSendRequest
System error code: 2
Message: The system cannot find the file specified
Perhaps Sunday evening is a bad time ..... or, perhaps, it is the same
problem as with Vanguard?
Any clues?
thanks
sj
surendar jeyadev
Postby surendar jeyadev » Sun Oct 06, 2013 5:00 pm
Some additional information.
I am using FM 11.5. I thought may be an upgrade would help and I tried to
check for upgrades via FM (Help->FundManager on the Web -> Check for Updates)
and I get
Message: The system cannot find the file specified.
Perhaps this gives some clue about the communication part.
thanks
sj
surendar jeyadev
Postby Mark » Mon Oct 07, 2013 9:10 am
Hi sj,
This sounds like you may have IE set to work offline. Start up Internet Explorer and under their "Tools" menu, make sure you do not have a check mark next to "Work Offline".
Postby surendar jeyadev » Mon Oct 07, 2013 4:39 pm
Thanks for the note.
Came back home this evening and tried to get my Vanguard transactions for
the quarter. It worked. Then I went back to Merrill Edge. It worked, after a
very long hesitation.
So, I guess there must have been something wrong in the communication and
the restart fixed it. We do not use IE -- we are strictly Firefox. I did not try
to change anything. I guess that as long as we have Windows, we need to
reboot first and ask questions later.
Looks like it is all fixed for now.
thanks again,
sj
surendar jeyadev
