Can't get fund prices from Morningstar UK server
Postby Exspextations » Sat Dec 20, 2014 7:13 am
I have a fund that the Morningstar UK website lists, but that I cannot download prices for using either the ISIN code (GB0031277790) or the code in the URL (VAUSA05W7Z). In each case I get the message:
Retrieve Starting
Quote Module Version = 473
Retrieving from server: (MORNINGSTAR-UK)
Requesting: "GB0031277790"
WARNING: Server used but did not update any prices: (MORNINGSTAR-UK)
or
Retrieve Starting
Requesting: "VAUSA05W7Z"
Any idea why the prices are not downloading?
Unfortunately, I can't find the fund listed on any other server.
Exspextations
Postby Mark » Sat Dec 20, 2014 10:01 am
Hi Exspextations,
I see the same problem. It should retrieve off the "id" value from the URL, which is the VAUSA05W7Z you mentioned. We will investigate, and post what we find back here.
Postby Mark » Sat Dec 20, 2014 4:43 pm
Hi Exspextations,
It looks like that ticker is not a "Unit Trust" available in the UK. It is a price quotes on that server, but FM only works with "Unit Trusts" from that server. For example, you can retrieve this:
http://www.morningstar.co.uk/uk/funds/s ... F00000SJQE
but if you look at the id you were using:
http://www.morningstar.co.uk/uk/funds/s ... VAUSA05W7Z
it says it isn't a fund available in the country GBR. That quote is available here:
http://www.morningstar.co.uk/uk/snapsho ... VAUSA05W7Z
but that isn't the URL being used by Fund Manager. Fund Manager is accessing their section that provides fund quotes, and this symbol is only available in a different section of their site.
Postby Exspextations » Mon Dec 22, 2014 4:18 am
Dear Mark,
Thanks for the feedback. Bizarre that Morningstar UK states that it is not a fund available in GBR as it is the fund in which my son invests for his personal pension scheme in the UK - a pension to which he can only contribute as long as he remains a UK tax payer. I guess I will just have to update manually as I can't find it quoted on any of the other servers included in FM.
Regards,
Exspextations
Exspextations
Postby Exspextations » Wed Dec 24, 2014 8:04 am
Dear Mark,
Eventually found the fund under Bloomberg - took some finding as Bloomberg changed the fund name and then failed to list it when searching for the fund under the institution that issued it.
Problem solved.
Exspextations
Postby Mark » Wed Dec 24, 2014 10:04 am
Hi Exspextations,
Excellent, glad you were able to find it.
Users browsing this forum: dellwo and 2 guests
