Is there a way to perform the following actions:
1. Change all stocks internet retrieve setting to default, as opposed to each stock one at a time.
2. Set prc retrieve to run automatically after hours at a pre-set time?
Ray
Default server
Yes and yes. Go to Options > Internet Settings to set default server and retrieve time(s). And select <Default Server> for each investment in Investment Properties > Internet Retrieve tab.
Hi theobaldr,
Just to add to moonlighter's answer... Normally you would keep your investment properties set to "<default quote server>", and only change this if an investment needs a different quote server than the majority of your investments. The default is set under "Options / Internet Settings...". If you've set all your investments to something other than default, there is no easy way to change all of them at once. To set a price retrieve to happen at a specific time you would need to use the command line interface, and Windows Task Scheduler. You can set FM to retrieve every X minutes, but to have it just happen once and a particular time you have to use the Task Scheduler. See the online documentation on the command line for more details.
Return to Prices and Transactions Who is onlineUsers browsing this forum: No registered users and 8 guests |
