Fidelity Investments Transaction Retrieve Problem
Postby Mark » Wed Nov 18, 2020 9:47 am
For those having trouble retrieving from Fidelity Investments, it appears in order to connect with this server you'll need to be using Window 10 with IE 11 installed.
Postby alan green » Wed Nov 18, 2020 3:04 pm
I just upgraded (free) to Windows 10 and that fixed the problem. Thanks Mark for taking the time to figure out the solution.
Alan
alan green
Postby Mark » Wed Nov 18, 2020 3:09 pm
Hi Alan,
Excellent, thanks for confirming the fix.
Postby Tnblade » Wed Nov 18, 2020 6:12 pm
Mark wrote:For those having trouble retrieving from Fidelity Investments, it appears in order to connect with this server you'll need to be using Window 10 with IE 11 installed.
I already have Windows 10 and IE 11 installed.
Tnblade
Postby Mark » Wed Nov 18, 2020 7:33 pm
Tnblade wrote:I already have Windows 10 and IE 11 installed.
Did you try resetting all the advanced settings under "Internet Options... / Advanced" inside IE 11 and rebooting your PC?
If you try that, and still can't get it working, please try uninstalling the IE 11 feature, and re-adding it. Maybe that will clear up whatever isn't set correctly. This is under "Turn Windows features on or off" in the Window's Control Panel.
Postby modelerMike » Fri Dec 04, 2020 3:25 pm
The past 2 days when trying to update FM's Fidelity portfolios using
'Retrieve Transactions' , I have been getting the 12029 error.
HOLD THE PRESSES;
Is this my problem ? From Mark's post above:
"For those having trouble retrieving from Fidelity Investments, it appears in order to connect with this server you'll need to be using Window 10 with IE 11 installed."
OTHER THINGS :
'Retrieve Transactions' on Fidelity accts, 2 months ago, worked fine.
Note that I had no problems doing 'Retrieve Transactions'
on another broker's accounts yesterday.
PC is Windows 8.1 Pro 64 bit
could this be a problem given that Microsoft has stopped
supporting 2013 vintage software ?
After reading all the relevant comments in this post,
I systematically disabled various firewall , anti-virus and anti-spam to see
if that would allow 'Retrieve Transactions' to work.
I updated the 'transactions module to the latest.
I also temporarily disabled 2-factor authentication
because that prevents Fund Manager 'Retrieve Transactions' processing too.
Still can't get past the 12029 error !
Any suggestions appreciated.
modelerMike
Postby Mark » Fri Dec 04, 2020 3:57 pm
Yes, the problem is you must be using Windows 10 to connect with the Fidelity server now. Their server is using a more modern secure connection method not available under older versions of Windows.
Postby modelerMike » Sun Dec 06, 2020 12:11 pm
Much appreciated, just wanted to double check that that is the issue.
Thank you Mark
modelerMike
Postby modelerMike » Mon Dec 07, 2020 3:44 pm
Running on Windows 10 with IE 11 worked !
Thank you Mark
modelerMike
