Yahoo Realtime Quotes very slow
Postby jnewton » Wed Aug 14, 2024 8:31 am
About 4 months ago (April 24) my Yahoo realtime quotes slowed dramatically and would skip about 20% of the quotes. Takes over an hour to download quotes. Historical quotes works fine-downloads prices in about 5-10 minutes, but i have to wait until about 6pm to download prices. In the past when the quote module got wonky, a new update generally fixed the problem. But this has been going on for 4 months. Any suggestions?
jnewton
Postby Mark » Wed Aug 14, 2024 8:47 am
Hi jnewton,
Which quote module version are you using? See "Help / FM on the Web / Check for Updates...".
It is in the nature of how quotes are requested from "Yahoo (Real-Time)". It won't be very fast. If you're looking for much better performance, please check out the "Yahoo" server instead. I believe that "Yahoo" provides almost real-time quotes, but in a much more efficient manner.
Postby jnewton » Wed Aug 14, 2024 9:02 am
MArk:
Thanks for quick response. I am using Quote Module 606, which I believe is the most current.
So I believe you are saying to switch from Yahoo Realtime to just Yahoo and that should improve response. Is that correct?
jnewton
Postby Mark » Wed Aug 14, 2024 9:30 am
Hi jnewton,
Yes, that is correct. It will be much faster.
Postby jnewton » Wed Aug 14, 2024 10:52 am
Mark:
In the Internet retrieve setitings, Yahoo is selected, but in the retrieval box it shows Yahoo(Realtime)
jnewton
Postby Mark » Wed Aug 14, 2024 11:33 am
Hi jnewton,
Under "Options / Internet Settings..." you can set the "default" quote servers. These may be overridden in each investment's properties, so you will want to check those too. You can change investment properties here one investment at a time, or globally by investment type or symbol.
