importing prices
Postby ishcabible » Sun Dec 06, 2009 5:17 am
when i try to import prices i get:
"requesting 40 (43)".
the next line reads "current" and a few symbols.
the third line is "retreive 66.99 per second"
and the screen goes blank in a second or two. no prices are downloaded.
thanks,
joe
ishcabible
Postby Mark » Sun Dec 06, 2009 10:03 am
Hi Joe,
The number in parenthesis (43) is how many prices have been updated so far. How are you determining that no prices were retrieved? The best place to look is in the Data Register with the "Prices" data type selected. Make sure you are sorting by Date, so the most recent closing prices are on the top of the list.
Postby ishcabible » Sun Dec 06, 2009 10:09 am
mark,
when i go to "data register", meaning i hit the button, nothing happens. the button does not work. also "Edit / All Data" is inoperable.
i am using the latest version 9.something. i have not gone to 10.2 yet.
thanks in advance,
joe
ishcabible
Postby Mark » Sun Dec 06, 2009 10:53 am
Hi Joe,
Hmm, the Data Register should always open. It does remember its position/size, so maybe it is towards the edge of your screen, mostly off the screen? If you still cannot find the Data Register, please use regedit to check this registry key:
HKEY_CURRENT_USER\Software\Beiley Software\Fund Manager\CurrentVersion\miscprefs
Look at the values beginning with: EAD_W
There should be 5 of them. What numbers does each show? These are the memorized position and maximized/restore status of your Data Register.
Postby ishcabible » Sun Dec 06, 2009 1:21 pm
mark,
ok! i finally found what you are talking about. here is what i have:
ead_wb 620
ead_wl 189
ead_wr 835
ead_wt 160
ead_wz 0
thanks again,
joe
ishcabible
Postby Mark » Sun Dec 06, 2009 4:25 pm
Hi Joe,
Okay. This means the coordinates/size are okay. It should open at the top/left of 189, 160, which should be on your screen. If you still are not able to open the Data Register please give us a call tomorrow. We'll connect to you, and see if we can't figure out why you're not seeing the Data Register.
