This dialog is available from the Edit / Distribution... menu command under the Graphs window. It is also available at Edit / Investment Data / Distribution... in the Portfolio Editor window, or by right clicking on any investment and choosing the Investment Data / Distribution... popup menu command.
Investments have a property that specifies how to record transactions for that investment. This option is called "Transaction Entry Preference", and is adjustable under the Investment Properties - Other Dialog. Depending on the transaction entry preferences each dialog will appear slightly different. For more details on each dialog, see:
Distribution transactions may also be recorded or modified from the Data Register.
When recording transactions it is important to correctly record the shares. See Recording Transactions Without Rounding Errors.
