Distribution  Transaction (No Fees) Dialog
This dialog records distribution transactions for investments with their "Transaction Entry Preference" set to "No Fees". "Cash" investment types will also always use this dialog, regardless of their "Transaction Entry Preference". The following fields are contained in this dialog:
Date
The date of the distribution.  For "Cash" investment types, there will be beginning and ending date choices. These should be filled in with the date range for which this distribution is being paid.
Value
The value of the distribution. (Example: 44.00)
Shares
The number of shares purchased with the distribution. (Example: 4.0)
Price
The share price paid for reinvested shares. (Example: 11)
Memo
Optional transaction note associated with this distribution
Exchange Rate to Default
Optionally specify the exchange rate between this investment's currency and the default currency to use for this particular distribution.  If no exchange rate is specified, the global currency exchange rate settings will be used.  This option is only available for investments that are not assigned to the default currency.  (more info)
Use Cash Account
When recording a distribution that is not reinvested, the corresponding cash will be entered into your default cash account.  In the case where the investment is not in the default currency and you have multiple cash type investments of differing currencies in the same sub-portfolio as the investment, you will be given the choice of which cash investment to use.  Otherwise, your specified default cash account will be used.
Choose a "Distribution Type" for this distribution.
See Recording an Account Fee Transaction if you are recording an 'Account Fee' distribution.  Account Fees and Return of Capital Distributions affect your tax cost basis. Account fees increase your cost basis, while return of capital distributions reduce your cost basis.
See Also
Recording Transactions Without Rounding Errors
Distribution Transaction Dialog
About Investments
Keyboard Shortcuts
Fund Manager Home
