Restore Command
This dialog is available from the File / Restore... menu command.
Use this command to restore data from a previously saved backup (*.fmb) file.  You can choose to restore only selected items from the backup, or everything.  You can also choose to restore each item to its original location, or to another folder you specify.
See Also
Backup Command
Automatic Backup
Fund Manager Home
