This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how the disclaimer is displayed in reports. Disclaimers are only available in the Advisor version. These options apply to all report types. The following options are available:
Display Disclaimer |
Select this option to enable showing the disclaimer at the bottom of all reports. |
Disclaimer Text |
The text to display at the bottom of each report. |
Font… |
Select this button to change the font used to display the disclaimer text. |
Center Text in Report Window |
When selected, the disclaimer text is displayed center aligned. When not selected, the disclaimer is displayed left aligned. |
