Report Preferences - Distribution Summary Dialog
This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how distribution summary reports are displayed. The following options are available:
Exclude Investments:
Exclude Cash Type Investments
Any investments of type “cash” will not be included in any distribution summary report when this option is turned on. See Investment Properties - General Dialog.
Exclude Default Cash Account
An investment specified as a default cash account will not be included in any distribution summary report when this option is turned on. See Portfolio Properties Dialog.
Exclude Tax Free Investments
Any investments with the "tax free" property" will not be included in any distribution summary report when this option is turned on.  See Investment Properties - Other Dialog.
Display Columns:
Specify which distribution types will be shown in the report.
Automatically Show Non-Zero Columns
Fund Manager automatically determines which columns to display, based on the values for each distribution type.  Distribution types with non-zero values will be displayed.
Specify Columns To Display
Manually choose which distribution types will be displayed
Do Not Display Line Items With No Distributions:
Any listed item (investment, symbol, type, etc) that has all zeroes for all distribution types will be omitted from the report.  This option does not omit sub-totals if they are on.
See Also
Report Window
Report Colors
Distribution Labels Dialog
Report Column Labels
Report Preferences Dialog
Fund Manager Home
