Report Preferences - Open Lots Dialog
This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how Open Lot Reports are displayed. The following options are available:
Display Columns:
Choose which fields (columns) are displayed in the report.  See Open Lots Report for a description of each field.
Investment Description:
Controls how an investment is described in this report type
See Also
Open Lots Report
Report Window
Report Filter Settings
Report Colors
Report Column Labels
Report Preferences Dialog
Fund Manager Home
