This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how all reports are printed. The following options are available:
On Color Printers Draw Background |
Controls whether the background will be printed when printing on a color printer. You can turn this option off to save ink, especially if you are using a dark background color. On black and white printers the background will not be printed. The background color is adjustable under the Report Colors Dialog. |
Print Footers At Bottom Of Page |
Controls whether the footers are printed at the bottom of the page, or right beneath the last report line. |
Print Page Numbers |
Controls whether the page numbers are printed in the report header |
Omit Page Number on First Page |
When printing page numbers on a report, turning on this option will prevent the "page 1" label from being printed. |
