This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify appearance preferences and which buttons will appear on the report toolbar.
To add a button to the toolbar, place a check next to the desired button. To remove a button from the toolbar, remove the check. Checks are toggled by clicking on the check box with your mouse. For descriptions of each available button, see Toolbar.
Appearance: |
Show Tooltips |
Toggle on/off the use of tooltips when the cursor pauses over a toolbar button. |
Show Labels Under Icons |
Turns on short descriptive text labels underneath the toolbar buttons. |
Button Size |
Select a preference for button size. The "Automatic" option will set the optimum button size based on the monitor resolution (DPI). |
