With this graphing option selected the graphs will show how the share price of the investment changed with time. Overlaid on the share price line will be vertical high/low bars. These bars indicate the trading range for that day. If there is no high/low data recorded for a particular date, no high/low bar will be displayed. Along the bottom of the graph will be displayed the trading volume versus time. The two sub-graphs will display data for the same date range, so correlations between the trading price and volume can easily be identified. The vertical scale of the share price graph is price. The vertical scale of the volume graph is in 100's of shares traded (volume/100). The horizontal axis displays the date. If auto scaling is on the vertical axis automatically scales to cover from the minimum to the maximum share price achieved during the displayed period. The volume sub-graph will always be auto-scaled from the minimum to maximum volume for the displayed period. The legend displays the price and value of the investment on the ending date of the graph, as well as the change from the previous day. The price is labeled with the current currency symbol of the investment, and the value is labeled with a V. The legend will not be displayed when the number of displays is 9.
To change the colors used in this graph use the Graph Colors Dialog. The 'NAV lines' color is used to draw the share price line. The 'NAV overlaid/MA 2' line color is used to draw the high/low bars. The 'NAV overlaid/MA 3' line color is used to draw the volume lines.
If the yields are turned on (View / Yields) they will be displayed above the graphs. See Yield Calculations for information on the reported yields.
