Mobile and Web Access
Your Fund Manager data can optionally be viewed with a web browser.  The Mobile/Web Access feature enables a view only look at your Fund Manager data.  A video tutorial is available for help using this feature.
To enable mobile/web access you use Fund Manager to create an account and upload your data.  All the menu commands related to this feature are available under Options / Mobile/Web Access.
Step 1:  Use Options / Mobile/Web Access / Account Settings... to specify a username/password, and select a top level sub-portfolio.  This username/password will be used from the web browser to log in and view your data.  The selected sub-portfolio will be what is uploaded and available for viewing.  To have all your data available to view, select your top-most sub-portfolio.
Step 2:  Check the options under Options / Mobile/Web Access / Preferences....  These options allow you to control the format of your displayed data and also control automatic uploads.  You can choose to have your data automatically uploaded upon program exit or at certain time intervals.
Step 3:  Upload your data by selecting Options / Mobile/Web Access / Upload Holdings.
You can now view your data online using a web browser by going here:
https://www.fundmanagersoftware.com/client/
Advisor Version:
When using the Advisor version a mobile/web account can be created for each client.  See Edit / Client List... and edit the properties of each client.  When you manually upload data using Options / Mobile/Web Access / Upload Holdings... you will be prompted for which accounts to upload.  You can choose to either upload all accounts, or only a specific account.  When you enable automatic uploads (Options / Mobile/Web Access / Preferences...) you can choose which accounts will be uploaded as part of the automatic upload.  The Client Statement Service is also available when using the Advisor version.
Privacy/Security Notes:
When you upload data only the following data are uploaded:
Sub-portfolio names
Investment names and/or symbols
Values
Prices
Number of shares owned
Change and % change from prior day
No account numbers or transaction retrieve usernames/passwords are ever uploaded.  The data that is uploaded is done so over a secure (HTTPS) connection.  Data viewed with a web browser is viewed via a secured HTTPS connection.
See Also
Web Client Portal
Video Tutorial
Fund Manager Home
