Importing Positions from DST FAN Mail
This dialog is available from the File / Import / Positions / DST FAN Mail... menu command.
Account position data can be imported from DST FAN Mail (www.dstfanmail.com) files.
Video Tutorial:  See the Tutorial on Importing Position/Transaction Files.
File to Import
Select which file to import.
Accounts to Import
Choose whether to import all accounts in the selected file, or only a particular account.  Use the "Scan File" button to fill in the list of available accounts in the importing file.
Import Options
Choose options for creating the new investments.
Choose whether to import all positions into a new sub-portfolio:
When this option is on, type the name of the new sub-portfolio where all the positions will be placed.  No existing sub-portfolios will be modified in this case.  When importing positions for reconciliation purposes, you should import into a new sub-portfolio.
When this option is off, Fund Manager will look through your existing sub-portfolios to try and find a match based on account number.  If no matching account number is found, the new sub-portfolio will be created at the top level of the portfolio hierarchy.  If a matching sub-portfolio is found, the positions will be updated in there.  When the sub-portfolio is already existing, Fund Manager will look for matching investments in that sub-portfolio based on CUSIP.  If an existing investment match could not be found, a new investment will be created.
Press the "Next" button after filling in all of the above fields.  The importing file will be read in, and you will be taken to the Preview Importing Positions page to see what transactions will be imported.
Important Note on Cost Basis:
When importing positions there is no cost basis data available.  Therefore, all positions will be created with a cost basis of zero.  To adjust the cost basis, use the Data Register and edit the initial purchase price and value.
See Also
Importing Positions
Importing DST FAN Mail Transactions
Importing DST FAN Mail Prices
Importing Transactions
Retrieving Transactions
Fund Manager Home
