This dialog is available from the File / Import / Positions / Fiserv ISS... menu command.
Position data can be imported from Fiserv ISS. Download a position file from the Fiserv ISS website. You can then import this *.PSN file into Fund Manager. During the position import Fund Manager will look for a corresponding *.PRI file with the same base filename as the *.PSN file. This *.PRI files contain closing pricing information. If found, this pricing information will also be imported.
PSN File to Import |
Select which *.PSN file to import. |
Accounts to Import |
Choose whether to import all accounts in the selected file, or only a particular account. Use the "Scan PSN" button to fill in the list of available accounts in the importing file. |
Import Options |
Choose options for creating the new investments. Choose whether to import all positions into a new sub-portfolio:
Press the "Next" button after filling in all of the above fields. The importing file will be read in, and you will be taken to the Preview Importing Positions page to see what transactions will be imported.
Important Note on Cost Basis:
When importing positions there is no cost basis data available. Therefore, all positions will be created with a cost basis of zero. To adjust the cost basis, use the Data Register and edit the initial purchase price and value.
Importing Fiserv ISS Transactions
