This dialog is available by pressing the Options... button from within the Report Settings dialog for an Executive Summary report.
This dialog allows you to specify preferences on how this particular Executive Summary report is displayed. Options that apply to all Executive Summary reports are available under the Report Preferences - Executive Summary Dialog.
Include "Year To Date" In Activity and Performance Summaries |
Whether or not to display values for the Year to Date period. When disabled, only values for the specified report date range will be displayed. |
Include "Inception" In Performance Summary |
Whether or not to display yields for the date range of inception to the ending report date in the performance summary section |
Display Removed Money as Negative Value |
Any field that removes money from the portfolio will be shown as a negative amount. This includes the Withdrawals, With-Dist., and Distrib. fields. |
Portfolio Performance Metric |
Whether to display a Portfolio Performance Summary section or not. If displayed, choose whether to display ROI Yield, Time-Weighted Return or both in this section. When using ROI the performance figures are labelled as "Portfolio Returns", and when using TWR they are labelled "Portfolio Performance". [more info] |
Display Graph |
Choose to optionally display a portfolio based graph on this report. The default of "Portfolio Value Bar Chart" is unique to this report. The other choices are the standard portfolio based graphs.
Display Comments |
Any optionally comments to display on this report. Use the Insert Field... button to add a calculated field into the comments. |
