Report Preferences - Executive Summary Dialog
This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how all Executive Summary reports are displayed.  Report specific options are available under the Executive Summary Options Dialog.
Cash Flow Style:
Displays the cash flow using the specified fields in the Portfolio Activity Section of the report.  (See External Cash Flow.)  The beginning value, gain/loss, and ending value will always be the same no matter which cash flow style is used:
Gain/Loss = End_Value + Distrib. - Beg_Value - Invested
Gain/Loss = End_Value + Withdrawals + With-Dist. - Beg_Value - Contributions
Gain/Loss = End_Value + Withdrawals + With-Dist. - Beg_Value - Contributions - Fees
Withdrawals and With-Dist. may vary between the case where Fees are displayed, and when they are not displayed.  When Fees are displayed:
1) Account fees recorded as "Reinvested" (or distributed with a corresponding sell in the default cash account) will add to "Withdrawals" and "Fees" in equal amounts.
2) Account fees recorded as distributed with no corresponding sell in the cash account (they sent in a check for the fees) will be pulled out of the With-Dist field, and put into the Fees field.
Pie Chart Type:
Select the type of pie chart to display, or choose "(None)" to not display a pie chart
Include Accrued Interest
Any accrued interest is included in the display of the Portfolio Activity Summary section.  Accrued interest as of the beginning date is added into the displayed beginning value.  Accrued interest as of the ending date is added into the ending value.  Gain is adjusted by the difference of these accrued interest amounts.
(By default, accrued interest is included in the yield calculations shown in the Performance Summary sections.  Whether or not to include accrued interest in yield calculations can be controlled in the General Preferences - Yield Dialog.)
See Also
External Cash Flow
Executive Summary Report
Accrued Interest
Report Window
Report Colors
Report Column Labels
Report Headers
Report Preferences Dialog
Fund Manager Home
