This graph type is only available in the Professional/Advisor versions of Fund Manager. This graph has an upper and lower section. You control what is plotted in each section with the Technical Analysis Dialog. You can call up this dialog in several ways:
The "F10" key on your keyboard
Right click on the graph and choose Technical Analysis... from the popup menu
The Graphs / Options / Technical Analysis... menu command from within the graph window
The two sections are displayed for the same date range. The upper section's legend displays the price and value of the investment on the ending date of the graph, as well as the change from the previous day. The price is labeled with the currency symbol of the investment, and the value is labeled with a V. The type of indicators being displayed, their settings, last value, and change from previous day will also be displayed in the legends of each graph section.
Keyboard shortcuts are available for quickly changing either the upper or lower graph's indicators. Use { or } to scroll the upper graph's indicator, and use [ or ] to scroll the lower graph's indicator.
To change the colors used in this graph use the Graph Colors Dialog. The following line colors are used in this graph:
Upper Graph:
Share Price Display: | |
Close |
NAV lines/Upper TA 1 |
Candlestick (up) |
Candlestick (down) |
NAV overlaid/MA 6 |
Indicator: | |
Simple MA | NAV overlaid/MA 1/Upper TA 2 |
Simple MA (2 lines) | NAV overlaid/MA 2/Upper TA 3 |
Simple MA (3 lines) | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
Exponential MA | NAV overlaid/MA 1/Upper TA 2 |
Exponential MA (2 lines) | NAV overlaid/MA 2/Upper TA 3 |
Exponential MA (3 lines) | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
Bollinger Bands (Middle) | NAV overlaid/MA 1/Upper TA 2 |
Bollinger Bands (Upper/Lower) | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
Lower Graph:
Indicator: | |
Accumulation/Distribution |
NAV overlaid investment 7/Lower TA 1 |
Average True Range |
Chaikin Money Flow (up) | NAV overlaid investment 7/Lower TA 1 |
Chaikin Money Flow (down) | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
Commodity Channel Index |
MACD Signal | NAV overlaid investment 7/Lower TA 1 |
MACD | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
MACD Difference | NAV overlaid investment 4/Lower TA 3 |
Money Flow Index | NAV overlaid investment 7/Lower TA 1 |
On Balance Volume | NAV overlaid investment 7/Lower TA 1 |
Relative Strength Index | NAV overlaid investment 7/Lower TA 1 |
Stochastic (%D) | NAV overlaid investment 7/Lower TA 1 |
Stochastic (%K) | NAV overlaid/MA 3/Upper TA 4/Lower TA 2 |
Williams %R | NAV overlaid investment 7/Lower TA 1 |
https://www.fundmanagersoftware.com/tanal.html
