This dialog is available from the Options / General Preferences... menu command.
This dialog page allows you to customize other miscellaneous settings. These preferences are memorized from session to session. They include:
Initial "Data Type" In Data Register |
Controls the initial selection for the "Data Type" when opening the Data Register. |
Action When Double Clicking An Investment In Portfolio Editor |
This option controls the performed action when double clicking on an investment in the Portfolio Editor. Choose to either open the Investment Properties Dialog or open the Data Register for the clicked on investment. |
Weekend Starts On |
Choose the first day of the weekend for your locale. Normally this is Saturday. |
Default Accounting Method for New Investments |
When a new investment is created, the accounting method investment property is set to this value, unless otherwise specified during creation |
Transfer Transactions OOP Calculations Use |
Specify preference on how to perform OOP calculations involving transfer transactions. Select to either use the original OOP cost of the transferred shares, or the market value of the shares on the transfer date. |
Send Price Update at |
Enables sending a daily portfolio price(s) alert. When this feature is turned on, an alert will be activated each weekday at the specified time. This is a unique alert, independent of your investment price alerts. Your current alert options will determine how the alert will be sent. This alert only uses the e-mail type of notification. E-mail notifications will report the current price of all open investments. The portfolio price(s) alert setting is memorized as part of your portfolio. |
Prompt Before Pasting Prices/Transaction |
Displays the "Pasting Prices/Transactions" dialog prior to pasting data. See Copying and Pasting Prices and Transactions. |
Prompt Before Deleting Prices/Transaction |
Prompts for confirmation before deleting any prices, transactions, notes, or alerts from the Data Register |
Create Log Files When Importing Transactions |
Log files related to importing OFX files or retrieving transactions and position information will be created. These log files can be useful for debug purposes. Log files are stored in the user's Application Data / Fund Manager folder. |
Allow Summing Values from Different Currencies |
Whether or not to sum amounts from investments with different currency types. If this option is off and the View / Exchange Rate Adjusted option is off, and an object combines values from multiple currencies, N/A will be reported. For example, a portfolio value will be N/A if that portfolio contains investments using more than 1 currency and the exchange rate adjusted option is off. This option does not affect graphs. For example, if you plot a Portfolio Value graph with the View / Exchange Rate Adjusted option off, the plotted values will be summing values from different currencies. Generally you would want to leave on the View / Exchange Rate Adjusted option when graphing, so that values are all displayed in your default currency. |
Allow Multiple Program Instances |
Whether or not to allow multiple copies of Fund Manager to run at the same time. When this option is off and a new copy of Fund Manager is started, the existing copy will be brought to the foreground, instead of starting a new instance. When this option is on you can run multiple copies of Fund Manager at the same time. In this case, care should be taken to not be modifying the same data files in different instances of Fund Manager, as only the last instance to save will have the changes saved. |
Automatically Un-Hide Investments With New Transactions |
If a share based transaction (buy, sell, transfer) is added/edited/deleted in an investment marked as hidden, Fund Manager will automatically un-hide that investment |
Transaction Dialogs Initialize Price |
When entering a new buy, sell, or reinvested distribution transaction the "Price" field will be pre-filled using the closing price on the selected transaction date. If the investment is a Cash type investment, or has a price of 1.00 the "Price" field will always be pre-filled, regardless of this option. |
Dialogs Initialized to Last Position |
When opening any dialog box, the dialog box will be positioned on the screen where it was last located. When this option is off dialog boxes will be centered on the screen. |
Seasonality Values are Normalized |
Choose how Seasonality values are calculated for both graphs and reports |
General Preferences - Display Dialog
General Preferences - Data Dialog
General Preferences - Yields Dialog
General Preferences - Toolbar Dialog
General Preferences - Menus Dialog
General Preferences - Data Register Display Dialog
General Preferences - Portfolio Editor Display Dialog
General Preferences - File Types Dialog
