This dialog is available from the Options / General Preferences... menu command.
This dialog page allows you to customize colors and fonts used in the Data Register. Use this dialog to change the data list font, text color for negative numbers, and a shading color for alternate rows. The "Restore Defaults" button reverts all fonts/colors to their defaults. A sample list view displays how the list view will appear with the current settings. The "Display Price/Value Fields With Currency" option displays the currency symbol for any price or value type field. How the currency label is displayed (whether before or after the value, and whether there is a space) is controlled by your currency format preference setting in the Windows Control Panel. The "Speed Mode" makes the Data Register operate faster. It does this by only filling in the most recent 260 data points (approximately 1 year) when listing the "Prices" data type. If there are more price data points to display, a "Show All Data" button will be displayed to allow you to display the full dataset. Speed Mode only affects the "Prices" data type, all other data types always show the full dataset.
General Preferences - Display Dialog
General Preferences - Data Dialog
General Preferences - Yields Dialog
General Preferences - Toolbar Dialog
General Preferences - Menus Dialog
General Preferences - Other Dialog
General Preferences - Portfolio Editor Display Dialog
General Preferences - File Types Dialog
