General Preferences - Portfolio Editor Display Dialog
This dialog is available from the Options / General Preferences... menu command.
This dialog page allows you to customize the appearance of the Portfolio Editor.  Use this dialog to change the font, text color for negative numbers, and a shading color for alternate rows in the list view.  The "Restore Defaults" button reverts all fonts/colors to their defaults.  A sample list view displays how the list view will appear with the current settings.  The "Show Totals in List View" option toggles on or off the display of totals along the bottom of the list view.  The "Show Gridlines in List View" option toggles on/off the display of row and column gridlines in the list view.  The "Display Price/Value Fields With Currency" option displays the currency symbol with any price or value type field.  How the currency label is displayed (whether before or after the value, and whether there is a space) is controlled by your currency format preference setting in the Windows Control Panel.  The "Display Percent Fields With %" option displays a percent sign after any number that is a percentage.
See Also
General Preferences Dialog
General Preferences - Display Dialog
General Preferences - Data Dialog
General Preferences - Yields Dialog
General Preferences - Toolbar Dialog
General Preferences - Menus Dialog
General Preferences - Other Dialog
General Preferences - Data Register Display Dialog
General Preferences - File Types Dialog
Fund Manager Home
