This dialog is available from the Options / General Preferences... menu command.
This dialog page allows you specify appearance preferences and which buttons will appear on the Graphs and Portfolio Editor windows, depending on which window type is active when opening this dialog box.
To add a button to the toolbar, place a check next to the desired button. To remove a button from the toolbar, remove the check. Checks are toggled by clicking on the check box with your mouse. For descriptions of each available button, see Toolbar.
Show Tooltips |
Toggle on/off the use of tooltips when the cursor pauses over a toolbar button. |
Show Labels Under Icons |
Turns on short descriptive text labels underneath the toolbar buttons. This makes the toolbar buttons larger. |
Button Size |
Select a preference for button size. The "Automatic" option will set the optimum button size based on the monitor resolution (DPI). |
General Preferences - Display Dialog
General Preferences - Data Dialog
General Preferences - Yields Dialog
General Preferences - Menus Dialog
General Preferences - Other Dialog
General Preferences - Data Register Display Dialog
General Preferences - Portfolio Editor Display Dialog
General Preferences - File Types Dialog
